Re: Graphite
Posted by Laszlo on Jan 26, 2007
Masking is definitely a good idea, but if you use a roller you can put on thinner coats which won't run. Tip them with a dry foam brush to get rid of the bubbles. And you're right about the beautification. That stark black against the shiney wood grain is quite a visual treat.
In Response to: Re: Graphite by John F on Jan 25, 2007
