Re: sit atop
Posted by Patrick Forrester on Jan 20, 2007
When you glass the inside, the smears will be about 1/5 as visible. You may not even notice them. I use a spreader, and maybe a razor blade if I am being real picky.
Your fillet material should be firm enough to not sag, but thin enough that it will not separate / have cracks as you smooth out the surface.
In Response to: sit atop by Hal on Jan 15, 2007
