Re: Painting in Basement
Posted by Jim E on Jan 18, 2007
I assume that the poyurethane is not one of those fancy two-pot formulations. I don't think polyurethane is any worse than oil-based enamel (you can use the same thinner with both, after all), although you will be covering quite a big area with it, so it's more of a quantity than a quality problem. If you run the fan, be sure that the incoming air is clean, without dust or bugs.
In Response to: Painting in Basement by Stan on Jan 18, 2007
