Re: understand. I use sto
Posted by Camper on Jan 15, 2007
I don't glue or wet the paper. I just hold a full sheet down on the glass with my hand. Using a Veritas holder, I position the blade at the right hand edge of the paper, halfway to the end. You can't easily use the whole length of the paper at once. After 4-10 strokes I slide it over to the next path, and so on till half the paper is dull. Then I rotate the paper 180 degrees and use the unused half.
It saves much time and mess this way.
In Response to: understand. I use stones by Charlie Jones on Jan 15, 2007
