Re: sit atop
Posted by Chris J. on Jan 15, 2007
Sounds like your using too much wood powder which make your fillets dark, lumpy and harder to spread. Play with your mixture - add some colloidal silica to smooth it up. Once you get a good mixture, write it down. For the outside of the hull, I assume you mean filling the seams. Add some microlite to this mixture and mask the seams to keep the mix off the hull.
Chris
In Response to: sit atop by Hal on Jan 15, 2007
- Re: sit atop by Hal on Jan 15, 2007
Re: sit atop by Chris J. on Jan 15, 2007
- Re: sit atop by Mac on Jan 15, 2007
- Re: sit atop by Hal on Jan 16, 2007
