Re: WR18
Posted by Mac on Jan 15, 2007
If I remember, I cut a flange - shaped "4mm thick wooden washer" to go under the deck as well. This is where I attached the top of the bag (with the top seam removed).
Once you get the VCP hatch, you'll figure it out. Just use the flange as a template.
Actually, if you're real good with exacto knives, you could go above the deck as well. The bag's diameter would have to be very close to the opening in the deck so there'd be no wrinkles.
Let us know how you make out if you decide to go this way.
Cheers
Mac
In Response to: Re: WR18 by Jim E on Jan 15, 2007
