Re: Frame problem
Posted by CLC on Dec 22, 2006
>>>> After the seems have meen epoxied will the boat have stiffened enough that the frames will still fit when the wires are removed? >>>>>>
After you've glued the seams, the boat will largely hold that shape. I've not experienced a lot of fighting when you do the reinstall on the frames in that boat.
In Response to: Frame problem by Tony on Dec 22, 2006
