Re: Found it
Posted by Greg Stamer on Dec 21, 2006
A common way to use these paddles is with the top edge tilted forward, called the "canted blade stroke". It helps to eliminate flutter and gives a very solid "bite". An old article that I wrote that discusses this is at http://www.qajaqusa.org/Technique/Greenland_technique_from_the_source.html .
If you haven't visited, the Qajaq USA site is all about Greenland kayaking. Some additional information on technique is given at http://www.qajaqusa.org/Technique/Technique.html . The forums on the site are very active as well.
Greg Stamer
In Response to: Found it by Jim E on Dec 15, 2006
