Re: Need some expertise
Posted by Warren on Dec 6, 2006
Oil and epoxy do not mix. If the electric guitar is an acoustic style then a varnish finish would be in order. If it is a solid body with electronic pickups then you might want to consider a wild paint job or some wood veneer overlays with a clear or tinted laquer finish.
In Response to: Need some expertise by Chris J. on Dec 6, 2006
- Re: Need some expertise by Andrew Sommer on Dec 6, 2006
