Re: Deck Beam Install
Posted by George K on Dec 5, 2006
David,
Installing the deck beam after glassing is no problem as you're going to have the deck cloth covering the sides an inch or so down. That'll cover the holes you've plugged. And, yes, glass the hull then plane the sheer clamps. You want a stiff boat when planing them.
George K
In Response to: Deck Beam Install by David Tudryn on Dec 5, 2006
