Re: Sand the Inside?
Posted by David Tudryn on Dec 1, 2006
Thanks. I learned a lot doing the inside first. When i get to the hull i'll go thinner on the epoxy applications. I did start sanding the cockpit area. I won't go crazy, but at least it will be smooth. I will matter to me, and that's the bottom line. As for the areas beyond the bulkheads, they're good enough as is. Thanks for the Reply!
In Response to: Re: Sand the Inside? by Alan Speakman on Dec 1, 2006
- Re: Sand the Inside? by Camper on Dec 1, 2006
- Re: Sand the Inside? by Jim E on Dec 1, 2006
