you really don't need a
Posted by Charlie Jones on Dec 1, 2006
brush. You already have a smoothing device in your hand. Just let the roller get pretty dry, then reach a finger ( gloved of course) out to stop it from rolling and drag it lightly back over the rolled on epoxy. Or cut a roller up into pieces about 3 or 4 inches long using a third of the roller length wise, and drag that back. But the roller you are using is the quickest and easiest.
By the way, I never sand epoxy until all the fill coats are on- I use scrapers to knock off nibs and any drips ( which you shouldn't have). Then I sand and roll on a final really thin coat, prior to finish sanding.
You do have to work in a continuous time frame so the epoxy doesn't really cure between coats, but there's no real reason to sand between coats unless you let it cure too long.
In Response to: Re: Laszlo has it right by Dave P on Nov 29, 2006
- Re: you really don't need by Laszlo on Dec 1, 2006
