Re: Laszlo has it right
Posted by Dave P on Nov 29, 2006
The only thing I would add is to use a wide dry foam brush. I did a single stroke about every couple of feet while rolling it on. I use the 1 inch diameter foam rollers that mount on the j handle. They are not cheap but give great results. Some friends who looked at the boat in process said my epoxy looked like varnish. Resist overbrushing. This method also works for spar varnish. Easier than spraying.
In Response to: air bubbles in epoxy, etc by Jay on Nov 27, 2006
- you really don't need a by Charlie Jones on Dec 1, 2006
- Re: you really don't need by Laszlo on Dec 1, 2006
