Re: Pin holes in varnish
Posted by Steve Miller on Nov 27, 2006
It is the thinner. Lacquer thinner will remove or soften fresh varnish. Cheap thinner can have other contaminants also that can cause coating problems.
I only use water to clean after wet sanding varnish. Rinse your boat well and dry with clean lint free towels. Let dry for a few hours or overnight and dust with a clean towel before the next coat. No tack rags either.
In Response to: Pin holes in varnish by Glenn on Nov 27, 2006
