Re: scarf overlap questio
Posted by CLC on Nov 16, 2006
There'll be some sort of seam but beneath epoxy it won't be any more obvious than a butt joint (yet stronger).
If you place the panel flat on a smooth surface, you can sand the faces of the scarfs with 120-grit paper to feather them out to a finer edge. I usually do this if I have the time.
In Response to: Re: scarf overlap questio by Kim on Nov 16, 2006
