Re: scarf overlap questio
Posted by Robert Hancock on Nov 16, 2006
Antal,
I have found that you have to plane the wood down to a very thin feather edge ,so you may want to check this. If the edge is not a realy sharp point you could try sanding the angle a bit. Good luck Robert.
In Response to: scarf overlap question by Antal on Nov 15, 2006
