Re: Skerry mainsheet rigg
Posted by Jim E on Oct 30, 2006
It's usually easier to hold mainsheets if the tail comes from the bottom, rather than the top. You can convert your existing arrangement by turning it upside down, and using a becket block at the bottom. This gives you somewhere to tie the end to. Also, you could use a bottom block with incorporated cam cleat, which CLC seem to have done on theirs.
In Response to: Skerry mainsheet rigging by Wilke Nelson on Oct 30, 2006
