Re: easy does it
Posted by Jim E on Oct 30, 2006
That does leave you with the problem of removing the last of the sanding dust. You can wash it off with clean water, then dry with paper towels and leave for a while, or you can wipe it with a dry rag and remove the last remnents with a clean lint-free rag just slightly dampened with thinner, so the dust will stick to it. Don't rub hard. If the varnish has been on a few days, it can better withstand the thinner treatment.
In Response to: Re: easy does it by CLC on Oct 30, 2006
- Re: easy does it by Blue on Oct 30, 2006
use mineral spirits next by Charlie Jones on Oct 30, 2006
- I prefer a good acetone by craig on Oct 30, 2006
- acetone? by Jim E on Oct 30, 2006
- perhaps- BUT- he was by Charlie Jones on Oct 30, 2006
- Wait by craig on Oct 30, 2006
- Denatured Alcohol by CLC on Oct 30, 2006
