Re: installing flush hatc
Posted by George K on Oct 30, 2006
My hatch sills are only wide enough for a piece of gasket material, 3/4", and I run my hatch frames as close as I can to the sills. I match the radius of the deck as closely as possible and take the radius after the hatch spacer and sill are put in as the radius will change a bit. I use internal bungies for hold-downs. The hatches are pretty tough and the afore mentioned cowboy entry would be feasable! I don't have a leakage problem, either. And neither do the hatches.....
George K
In Response to: Re: installing flush hatc by CLC on Oct 30, 2006
