Scarf Joint Router Jig
Posted by Chris J. on Oct 24, 2006
Glenn....I've added a detail photo of my scarf joint jig on the link below. Hope you can read the dimensions. It's easy to make and it takes the guess work out of cutting the joints. I made mine to accommodate the 11" blanks called for on the Chesapeake 16 with 8:1 joints in the 4mm plywood. I also used it for the small deck joint at the bow. Perfect results every time. Let me know if you have any questions. Good luck.
Chris
http://www.flickr.com/photos/65248854@N00/278624487/
In Response to: Re: Winter Storage Option by GLENN on Oct 24, 2006
