Re: End Pour vs dam metho
Posted by LeeG on Sep 26, 2006
Chris,So you have the deck on? How far to the ends did you make the sheer clamps go? The reason I ask is that if you cut the sheer clammps to the end you don't need more than a couple oz, if you cut them 4"-5" short as recommended in the instructions you'll need at least 6oz with the hull tilted deck down. If it's a medium cure epoxy you'll have to pour in 1oz at a time, wait till it cures/cools off then pour another oz. Wood flour is a fine thickener, cabosil will increase the heat/rate of cure.
In Response to: End Pour vs dam method by Chris on Sep 26, 2006
- Re: End Pour vs dam metho by Tim on Sep 28, 2006
been going on for years by LeeG on Sep 28, 2006
- Re: been going on for yea by CLC on Sep 28, 2006
- my assumption is wrong by LeeG on Sep 28, 2006
- Re: my assumption is wron by Laszlo on Sep 28, 2006
- pokey bow by LeeG on Sep 28, 2006
