Varnish?
Posted by Matt Croce on Sep 25, 2006
OK, I know that varnish is probably the easiest finish to brush on, giving the most durable finish for the least amount of work...BUT...
What if, say, I had access to a huge paint booth and spray equipment (at work, courtesy of your tax dollars)...would my first choice still be to use varnish? Or should I go with automotive clearcoat or something similar? Also, if I'm spraying "it" on (whether varnish or otherwise), should I still go with 3-5 light coats, or should I spray a couple of heavier coats instead?
CLC -- any input you have would be especially appreciated.
Thanks Matt
- Re: Varnish? by TIm on Sep 25, 2006
- Re: Varnish? by Jim E on Sep 25, 2006
Re: Varnish? by J. Schott on Sep 25, 2006
- JUST bought clearcoat by Charlie Jones on Sep 25, 2006
- Re: JUST bought clearcoat by Matt Croce on Sep 26, 2006
- Re: JUST bought clearcoat by Bill Aileo on Sep 26, 2006
- ok- we spray ZSpar 2015 by Charlie Jones on Sep 26, 2006
- Re: Varnish? by Mike Hanks on Sep 26, 2006
- Re: Varnish? by Steve Miller on Sep 27, 2006
