Re: Epoxy over Veneer?
Posted by J. Schott on Sep 24, 2006
Here's a pic of the light set up, or as Kurt calls it, "The rotisserie". I used heat lamps. If you do use them, do so with great caution. I had an infared thermometer to track surface temp because they worked almost too well. Use flood lights and see what you can get the surface temp to. It was kind of wierd, it was cold enough in my garage that I could see my breath anywhere but near the boat. Keep us updated-Joey
In Response to: Re: Epoxy over Veneer? by J. Schott on Sep 24, 2006
- Re: Epoxy over Veneer? by Alan Speakman on Sep 24, 2006
