Epoxy over Veneer?
Posted by Kathrine on Sep 23, 2006
I'm still in the process of repairing the holes in my deck, but I think the patches will work out OK. The biggest hold-up is the weather. I do not have a heated work space and I'm pushing the temperature limits of the epoxy. It's below freezing at night and only in the 40's-50's during the day, so it takes DAYS between epoxy coats before they are hard enough to sand. Geez, there was even 2 inches of snow on the groung last week! I'll keep you all posted.
At this point I'm thinking of ways to use a design to hide the scars. Paint would be the easiest fix, but I really want to keep the natural wood grain finish. Rather than paint, I'm leaning towards using a veneer overlay design to hide the patches. My big question is can I just put several coats of epoxy over the veneer and then varnish, or would I have to fiberglass over the veneer? I did not fiberglass the deck in the first place and I really don't want to. If I have to fiberglass over veneer overlay, I will definitely go with a painted design.
- Re: Epoxy over Veneer? by J. Schott on Sep 23, 2006
- Re: Epoxy over Veneer? by Laszlo on Sep 24, 2006
Re: Epoxy over Veneer? by Doug Judd on Sep 24, 2006
- Re: Epoxy over Veneer? by Kurt Maurer on Sep 24, 2006
- Re: Epoxy over Veneer? by Kathrine on Sep 24, 2006
Re: Epoxy over Veneer? by Alan Speakman on Sep 24, 2006
- Re: Epoxy over Veneer? by J. Schott on Sep 24, 2006
- Re: Epoxy over Veneer? by Alan Speakman on Sep 24, 2006
- Re: Epoxy over Veneer? by Darryl on Sep 24, 2006
tidbit of info by gober on Sep 26, 2006
- Re: tidbit of info by Tim on Sep 27, 2006
