Re: photo link
Posted by Jim E on Sep 20, 2006
I'll jump in first. The good news is that the damaged areas look to be easily accessible from the inside. I'm guessing this was a kit, so you might not have enough okume on hand to make the patches. If that is so, you'll need to get some from CLC. Perhaps they can send a small sheet? You'll need enough to replace each damaged area, including peripheral cracks, and to make an oversized doubler that glues underneith each area and supports the patch. You'll be getting some detail on how to do the repair as this thread proceeds. The repaired sections will be stronger than the original. How well you do the job will only make a cosmetic difference.
In Response to: photo link by Kathrine on Sep 20, 2006
