Re: Test Screw AOK
Posted by Monterey Matt on Sep 18, 2006
I've screwed in another eight or nine and this was the only one that didn't "catch" or bite at the end -- I'm hoping the adhesive sealant will take care of cementing it. I did a test run of the bungee (took it off to avoid putting stress on the screws while they set) and it was already a very firm fit.
The tippy top layer of epoxy's about 30 hours old, the bottom layer that it's biting into is over 48 hours old by now and should be hard enough. Heh heh.
OK, back to the carport and more screwin' around.
In Response to: Re: Test Screw AOK by Jim E on Sep 18, 2006
