Re: Screws through Nylon
Posted by Jim E on Sep 18, 2006
Matt, If your screws have still have thier points (see prevous thread), then they should go through the webbing and just push the weave of the way. I don't have any CLC-type webbing handy (I will tomorrow) to support this statement! Even if it does get cut, the washers should prevent fraying. Do a test and see. If you do make a heat sealed hole. make it slightly bigger than the screw, so the screw won't crack the heat sealing.
In Response to: Screws through Nylon Web. by Monterey Matt on Sep 18, 2006
- Re: Screws through Nylon by George on Sep 18, 2006
Re: Screws through Nylon by Jim E on Sep 18, 2006
- Test Screw AOK by Monterey Matt on Sep 18, 2006
- Re: Test Screw AOK by Jim E on Sep 18, 2006
- Re: Test Screw AOK by Monterey Matt on Sep 18, 2006
