Narrower table
Posted by M Davis on Sep 13, 2006
When I set up to build a WR18 I cut 20" off of the end of a 4x8 sheet of plywood. I then ripped the remaining 76" long piece into 16" widths.
The three 76 x 16 inch tables can be used separately or joined together for gluing up scarfs and the 20" x 48" piece made a good table for holding tools and mixing epoxy.
The best part was getting the work surface up to counter height. My back was much happier then trying to work on the floor.
Happy building
In Response to: Re: Buying a boat kit by John F on Sep 13, 2006
