Re: glue globs in cockpit
Posted by Darryl on Sep 11, 2006
Jim, Next time don't use so much epoxy. Spread it thin and then remove most of it. I installed only the first two coaming layers and the last the next day. You won't have to sand either the outside or inside and the lip won't be in the way if you do have to sand.
In Response to: glue globs in cockpit by Jim Stillman on Sep 10, 2006
- Re: glue globs in cockpit by Jim Stillman on Sep 11, 2006
Re: glue globs in cockpit by Darryl on Sep 12, 2006
- Re: glue globs in cockpit by Jim E on Sep 12, 2006
- Re: glue globs in cockpit by Jim Stillman on Sep 12, 2006
