Re: no need- it's good
Posted by Alan Speakman on Sep 5, 2006
Hi Matt,
It shold be fine unless it's been exposed to freezing... Beyond that, about the worst-case scenario is that the resin may have turned white... If that happens, all you have to do is submerse the container in hot water (above 120 degrees F) until the resin crystals go back into solution and all will be well...
Alan
In Response to: no need- it's good by Charlie Jones on Sep 5, 2006
