Re: Varnish Prep
Posted by George K on Aug 31, 2006
Blue,
If, indeed, you have gone through the cloth in the afore mentioned areas, by all means you should fix them before varnishing. Cut some 4 oz. cloth on the bias as it will go around those areas easier, a couple coats of epoxy feathered at the edges (being careful NOT to sand through this time!), and after the varnish is applied these patches will disappear. Seeing the weave isn't a bad thing, sanding through is.
Happy building.
George K
In Response to: Varnish Prep by Blue on Aug 30, 2006
