Re: Paint
Posted by J. Schott on Aug 21, 2006
Can you post some pics? If you got the first coat down smoothly and only changed by using a finer grit, sounds like your technique is good. What paint are you using, and have you contacted the manufacturer? It might help to see what is happening.-Joey
In Response to: Re: Paint by John Beck on Aug 21, 2006
