Re: adding a small keel..
Posted by Jim E on Aug 19, 2006
Eric, I thnk you are describing a skeg. The can be fixed, or, more usually, retractable, The rectractable kind is more usual. CLC sells kits which can be retro-fitted to exixsting CLC kayaks. The link to to a page which describes how a retractable skeg is fitted. If you want something even simpler, you can have a fixed skeg, which is usually a strip of solid wood, maybe 2" deep and 1' to 2' long epoxied to the outside of the hull near the stern. You would need to experiment a bit with temporary ones to find the right dimensions.
How to fit a skeg
In Response to: adding a small keel...may by Eric on Aug 19, 2006
- Re: adding a small keel.. by Eric on Aug 19, 2006
Re: adding a small keel.. by Alan Speakman on Aug 20, 2006
- Re: adding a small keel.. by Jim E on Aug 20, 2006
- Re: adding a small keel.. by Eric on Aug 20, 2006
