Re: New Skerry sailing ri
Posted by Donald on Aug 17, 2006
When I saw the first Passagemaker, I knew that was the rig I wanted. So I called John and asked him if it would work. That's when I decided to go forward with the construction of the Skerry. I would not row with the mast up as I set mine up as "mast stepped with the jib flying" as opposed to having a seperate forestay. If I had the forestay, the boom would not be in the way rowing as its laced to the bottom of the main sail and would be in the bottom of the boat. The fastest day was, white caps, speed unknown. It was really fast and required relentless concentration, however it was more stable than I anticipated. The extra time to set up for sailing is well worth it. Again thanks to John for the drawings and help. I did have to shorten the shrouds, otherwise everything was a perfect match.
In Response to: Re: New Skerry sailing ri by Mark on Aug 16, 2006
- Cool. by CLC on Aug 17, 2006
Re: Cool - PMD Sailrig by John Pollard on Aug 18, 2006
- Re: Cool - PMD Sailrig by CLC on Aug 18, 2006
- Re: Cool - PMD Sailrig by Ron Eike on Aug 18, 2006
- Re: Cool - PMD Sailrig by Peter on Aug 18, 2006
- Re: Cool - PMD Sailrig by John Pollard on Aug 18, 2006
- Re: Cool - PMD Sailrig by Jim E on Aug 18, 2006
- Re: Cool - PMD Sailrig by Laszlo on Aug 18, 2006
- Re: Cool - PMD Sailrig by Ron on Aug 20, 2006
- Re: Cool. by CLC on Aug 18, 2006
