Re: Epoxy on shopcam lens
Posted by Laszlo on Jul 29, 2006
7/28 - Looks like you could take that assembly which is being glassed in the foreground, flip it over and put it on top of that hull with sponsons in the background.
Nice one-piece rounded decks. Not only does it look better, but with that arch, as opposed to a linear joint, it's probably a lot stronger.
The cockpit also seems to have 2 levels, instead of being flat. That should make seating a lot more comfortable than a flat bottom.
In Response to: Re: Epoxy on shopcam lens by Peter on Jul 25, 2006
- Re: Epoxy on shopcam lens by Mac on Jul 29, 2006
- Re: Epoxy on shopcam lens by mike noeske on Jul 29, 2006
