Re: Holes in bow for loop
Posted by Doug Judd on Jul 20, 2006
I used the alternate method drilling through the hull and endpour. I drilled just until the point of the bit penetrated the far side of the hull which indicated the center of the hole. Then I finished drilling in the opposite direction to minimize any chipping or breakout of the wood. Finally I touched up the bare wood with a coating of epoxy to seal everything.
In Response to: Re: Holes in bow for loop by gober on Jul 20, 2006
- Re: Holes in bow for loop by John S. Short on Jul 20, 2006
- Re: Holes in bow for loop by craig on Jul 20, 2006
