Re: What did I do?
Posted by jerry on Jul 11, 2006
I don't think trying to fill the delaminated areas will work for this repair. It's about 5 inches long and I could probably tear half of the rim off without much effort. I also wanted to make the rim a little higher off the deck. It's hard to get the spray skirt cord under right now. You mentioned to make a pattern before I start "destruction"...loaded questions do I do that? I thought I might be able to trace it once I took it off, but if it breaks that is not an option, so how do make the template? Next, do I need to put glass on the new rim and coming?
In Response to: Re: What did I do? by Robert on Jul 11, 2006
