Re: Options for hull pain
Posted by Steve Miller on Jun 30, 2006
Also note the the two part linear poly's are very toxic and can kill you (as in dead, no more kayaking!) if used wrong. You should use a fresh air supplied repirator! The Interlux and the Awlgrip fall into this category. The exception is the water base 2 part from System 3. It has no isocyanite (or however you spell it).
In Response to: Re: Options for hull pain by ted on Jun 23, 2006
