Re: Bulkheads
Posted by CLC on Jun 20, 2006
>>>>>>>It's currently placed an inch aft of where it should be >>>>>>>>
If you moved the bulkhead forward one inch, it would flare the sides out to (more closely) match the angles on the bulkhead sides, and the gap on the bottom facets would disappear.
You'll need to ease off on your hull-twist-prevention rig so that the boat's a little wider; no big deal. Must be slightly denser sheer clamps.
In Response to: Bulkhead Woes by Tim M. on Jun 20, 2006
