Re: Swirl marks
Posted by Dave Houser on Jun 14, 2006
Sanding marks will disappear with varnish (I use Captains) but only after several coats. It is a bit frustrating when applying the varnish because when you wet on the varnish coat it looks so smooth then as it drys it sinks into the scratches. It takes several coats with sanding in between to fill the lows. You really do not want to deal with scratches from 60 or 80 grit. Even 100 grit takes more varnishing effort than just sanding the epoxy finer.
In Response to: Re: Swirl marks by M Davis on Jun 12, 2006
- Re: Swirl marks by J.Schott on Jun 14, 2006
