Re: John H among others
Posted by craig on Jun 9, 2006
Do you guys think that a spanish windlass will work to pull it together? This is just a block of wood with two holes and a length of line. Stick the line throigh the holes and tie knots in the end. put the line over your strips and twist it down until you can get a smaller clamp on it, or pull it down tight and block the wood so it won't unwind. Good Luck, I know that 6" c-clamps are industrial strength and cost to match
In Response to: Re: John H among others by don foote on Jun 9, 2006
