Re: Honda and trailer
Posted by Brad Shook on Jun 7, 2006
Go to your owners manual for the Honda civic to locate the maximum trailer weight that it will pull, find out how much the CLC trailer weighs + the weight of the boat you will be adding to it, and if all of that weighs less than the maximum pulling capacity, you should be all set...especially if it is a manual transmission, which which take the overdrive problems on an automatic out of the picture. I towed a 12' small pram and galvanized trailer with a VW Jetta with a manual trans for a couple years with no problems. Good luck.
In Response to: Honda and trailer by Nelson on Jun 7, 2006
