Re: Shearwa gask tipCLC?
Posted by Darryl on May 27, 2006
I would stick the foam to the hatch cover as instructed. CLC was in a hurry as I recall and left out the sil altogher to make a upcoming appearance. Last thing you want is the glue of the foam sitting in salt water. Also I used wooden hooks instead of the metal to save my fingers. It takes a little learning to hook the bungees up but easy to unhook.
In Response to: Re: Shearwa gask tipCLC? by James Eager on May 27, 2006
