Re: Sanding problem
Posted by Doug Judd on May 25, 2006
Kev, lightly moisten the areas of concern with water. Not much, just a barely damp cloth. If the weave disappears, and it likely will, you are good to go.
No, one can't build boats and get too much sanding.
Good luck.
In Response to: Sanding problem by Kev Robinson on May 25, 2006
