Re: Coaming Glass
Posted by Chris J. on May 19, 2006
Thanks for the great ideas guys. I was a little apprehensive about the coaming, especially how rough it looked once I glued it up. I learned how to use a spokeshave for the first time. What a neat tool (make sure the blade is right-side -up)! I kept it very sharp and had the coaming cleaned up and looking great in about 2 hours. Just some fine sanding left to do. I've been building 2 CH16's in tandum over the winter. Construction will be complete this weekend, then sanding and varnish. Dave - how do you post one picture under your response like you did with your coaming?
In Response to: Re: Coaming Glass by Dave Houser on May 18, 2006
