Re: Coaming Glass
Posted by Chris J. on May 16, 2006
I assembled my coaming in 2 stages so I could clean up the spacer's outside before attaching the rim...but I don't know if the cloth lay well when going around the 6mm outer edge without trying to pull away and bubbles forming....I'm thinking that if I trim it at the outer edge at least all the exposed surfaces are covered...
In Response to: Re: Coaming Glass by Doug Judd on May 16, 2006
