Re: footbrace studs insta
Posted by Tim on May 4, 2006
Hey. I just got through installing the footbrace mounts in my WR18. Went very well I must say. I got them from CLC. Simply marked out the locations. Cut the tape reinforcements provided, mixed up a dab or two of thickened epoxy and smacked em down. Then mixed up some more un-thickened epoxy and wet out the cloth. I used the rail as a guide in case some strange alien force came through and moved them while the epoxy cured. Did one side at a time. A heat lamp sped up the cure enough so that I could get them and my end pours done in the same day. Best of luck to ya!
In Response to: footbrace studs install by mick w on May 4, 2006
