Re: epoxy
Posted by George K on Apr 26, 2006
D,
I've only used System 3 and MAS epoxies and have no experience with West Systems but you want to get the slow hardener. If you go to www.westsystems.com and click on the "Using WEST SYSTEM Epoxy" tab there's everything you need to know about it! As far as the fiberglass schedule is concerned just give Ed or John at CLC a call and they'll be more than happy to help you out. Good luck on the build and use this forum as much as you need. Nothing but a bunch of great guys here. And then there's Kurt! Seriously, go to the "Site Map" tab here, then to "Customer Pages' Links" under CLC News and look for the "Pair O Mill Creeks Project". Lots of info and entertaining as well.
In Response to: epoxy by D on Apr 25, 2006
