Re: Glass Hull and Deck
Posted by Tim on Apr 20, 2006
If I understand you correctly what you wish to do is glass the hull and the deck board at the same time but as seperate process. If that is the case then the answer would be NO, it can't be done. Why? Cause you would never get the deck to bend. Fiberglass and epoxy is pretty tough stuff. My two cents
Peace out.............
In Response to: Glass Hull and Deck by ted on Apr 19, 2006
- Re: Glass Hull and Deck by LeeG on Apr 21, 2006
- Re: Glass Hull and Deck by Ted on Apr 22, 2006
