Re: Is it possible to....
Posted by George K on Apr 17, 2006
It is possible. I use a roller to put on fill coats so I can get a thin coat down. Tip it out with a foam brush. Watch it for a while and use the foam brush to smooth out any runs. You'll be able to catch most of them and avoid a lot of sanding or scraping. As far as sanding between coats, if you're using MAS, West or System 3 there's no need to sand between coats. It will only help the bond if you do, however.
In Response to: Is it possible to.... by Petewp on Apr 15, 2006
